Sweep along a helix
Can anyone explain this behaviour?  When I try to sweep a simple circle along this helix it seems to step it off one turn to the left instead of starting the sweep at the original X-section circle? Any ideas welcome. Thanks in advance.
here's a video (sorry I'm using an academic license so I cannot post the par file):
here's a picture...
Edinburgh University
Betreff: Sweep along a helix
Hi @FrankMill
on the first view I was not able to see any mistakes etc.
But for this geometry I simply would create a helix protrusion directly without creating the helix curve.
BTW do You have any maintenance pack installed onto ST10?
Wolfgang
Hi @FrankMill
and can You upload the file too, I wil try to open it and see what happens here.
Wolfgang
Re: Sweep along a helix
Can't reproduce.
Do you have the academic ST10 with MP3?
Help>About
LMGi
www.TLMGi.com
Wolfgang,
the mistake is that the surface starts to the left of the actual circle that is used for the cross section. This also means that the sweep does not go to whole extent of the helical sketch.
I can't post the file because I have an academic license so you wouldn't be able to open it.
yes Academic ST10 MP3
Okay, I've tried to simplify it and I've now installed MP5.  I think this is a program fault.
A video is here:
https://www.screencast.com/t/JTKLag4m
And a picture...
Hi @FrankMill
can You upload the part file?
Wolfgang
Hi there @FrankMill,
I'm guessing there is likely an issue with the profile/path relationship.
Is there a reason for using a swept surface?.......you could create this in one "Helix" feature.
