Switch Text
With this video included shows switching text 1 and text II. I would like to rename text 1 as a part and rename text II as a part as well. By using a switch, without adding another part. I've tried Display Configuration nothing would work for me.
Thak You
Greg
(view in My Videos)
Re: Switch Text
Hi Greg,
I'm a little lost as to what you want to do specifically. You've made groups out of features in the ordered environment of a part, and you want to make them parts without making them parts? What is the end goal behind switching the two text displays? Why not just have two actual separate part files, one which contains 'text 1' and one which contains 'text 2'?
-Dylan Gondyke
