Switch location?
Honored Contributor
Honored Contributor
Where is the switch that turns on sketch display in the pathfinder display?
Re: Switch location?
In the right-click context menu, though this does not toggle it in the path-finder but in the graphics area.
and in an assembly, right-click in the pathfinder and pick Show/Hide component:
Esteemed Contributor
Hi Scott,
If you right click on the component pathfinder title, there is a display settings there.....funny thing, it's still called "Ordered Pathfinder Display", even in a Synchronous PAR or PSM.
Honored Contributor
Honored Contributor
Thank to both of you.
Some of the naming and switch locations are difficult to remember as I learn the software.
My brain is full just trying to keep track of the actual designs I'm working on.
It was Sean's answer I was looking for and could not find. Your right, the naming is not what you would think that is.
I HEAR THAT!!!!.....  Robot wink
Yeah, @12GAGE had written exactly what was sought, but didn't have a clue; so thought of throwing my best guess. Glad we have the correct answer.
Honored Contributor
Honored Contributor
That menu item should be labeled "Pathfinder display options" The word display or options could be removed to save space. So either "Pathfinder Display" or "Pathfinder Options"
