Switching axis?
N/A
I have never used solid edge before and am trying to self-teach but I have no idea how to switch from the z/x axis to the z/y axis so everything I'm making is on the same plane right now. Impossible to make anything 3-D
Re: Switching axis?
Siemens Master Siemens Master
Siemens Master
Make sure to do the tutorials that walk you thru creating a part. In brief:
Draw end connected lines and when you close the shape it should shade the enclosed region
Choose the select tool and select the region
Grab the arrow that comes up and drag it to create your solid
Sent from my iPad using Tapatalk HD
