Symmetric Diameter to Theo. Sharp
Does anyone know if this feature is broken or can it be an enhancement?  Noticed in drafts, you can't select a theoretical sharp corner with the Symmetric Diameter feature as you can a Distance Between dimension.
I use this feature all the time an have to constantly draw a point in the views.
Matt
Re: Symmetric Diameter to Theo. Sharp
No you can not achieve this with symmetric Diameter. Don't know if there's a enhancement out there. never understood why you can't
