Sync Mirror Inquiry
I am looking for help to understand the Mirror command within Sync.
I attached the Vid:
(view in My Videos)
Why am I getting only the surfaces mirrored, not the whole extrusion?
Thank you for any answer,
Arek
Re: Sync Mirror Inquiry
I think you'll find that mirror works fine if you also pick the triangular end caps (at both ends of course).
/Harri
