Sync Part not able to move
In the previous ST5 installed before the factory setting. The sync part with the steering worked fine. This second time the sync part steering doesn't work. I had to use move component in the assemble just to get started. Movement in the assemble with the drag is to erratic. So, I tried to go with the sync parts I cannot do anything. Being on top of a slow computer I have 700 parts to install.
 http://screencast.com/t/bTBS2KRcMz
Greg
It's because you are in orderd mode. Switch to Sync mode...
It's because you are in orderd mode. Switch to Sync mode and It will work fine
Laurenj
Were you able to fix your problem? I just realized you ca...
Were you able to fix your problem? I just realized you can move a sync face while being in ordered mode. So my earlier suggestion may have not been helpful for you...
Laurenj
Re: Were you able to fix your problem? I just realized you ca...
No... I went through the self-paced training on moving faces and rotating.
The results are the same cannot move
Greg
