Sync sheet metal "lift"
I'm trying to "lift" the two sides of this sheet metal tube.
I would like them "lifted" 50 mm., but it select the entire surface and not just the selected one.
Betreff: Sync sheet metal "lift"
Hi @Kenneth
just switch back to sync mode and turn off the thickness chain option.
Then everything will perform as wanted.
Awesome, worked perfectly.
Thanks again.
Hi @Kenneth
welcome
