Synchronous - How to Change Helical Coil
I must be missing something. How do you change the length or height of a helical coil in synchronous after it is created?
David McMahon
Solid Edge 2019
HP Z2 Mini, Windows 10
Re: Synchronous - How to Change Helical Coil
Hi there @David_McMahon,
You can't....this remains a procedural feature, which currently is best handled in Ordered mode.
@SeanCresswell
Thanks for the quick reply. OK, at least that confirms I was not missing something basic. I will work it in ordered.
David McMahon
Solid Edge 2019
I don't know if you intend to make a solid body from this or not.  If you do, I've found that editing solids in Synchronous is much more efficient than trying to edit sketches in synchronous.  See the video for how I would do the edits you are asking if you make it a solid using the Helix command.
(view in My Videos)
Brian Fritz
Solid Edge Certified Professional
ST10 latest MP
