Synchronous Sheet Metal Issue
Hi Edgers,
I'd like to ask for help regarding creating sheet metal part in Sync.
How to do it?
Please see attached video.
Arek
(view in My Videos)
Betreff: Synchronous Sheet Metal Issue
Hi @arekkul
it is exactly what the message says:
"Such a flange isnot possible as synchronous feature!"
A sync contourflange needs at least a small plane start and end surface and can not consist of a bended (cylindrical) face only.
So You either can add short linear extensions to the circle
or You switch over to Ordered, where such a contour flange is possible too!
Wolfgang
Hi @hawcad
thanks for help.
I'm new to Sync hence silly questions.
regards,
Arek
NO silly questions! we ALL learn by seeing new and old perspectives!!!
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
Hi @arekkul
no silly question at all, per definitionem a silly questions doesn't exist, only foolish answers!
Sorry for the late answer, but I was on phone the last half an hour.
And there are differences between sync and ordered in reagrd what is possible to do, and how it is possible.
But the Big Bang is, that You can use both methods together as You like and as You need.
I always preach to think about integrated modelling rather than synchronous modelling or ordered modelling.
Use both - thats the message!
Integrated is Sync plus Ordered!
Wolfgang
