Synchronous and Ordered Templates
Taking a hint from this line in the GettingStarted.PDF, I tried to figure out setting templates for Ordered and Synchronous Parts:
knowing that the startup environment is a global setting under the Helpers tab:
Does any one know a way to setup separate templates for Ordered and Synchronous ?
Thanks.
~Tushar
Re: Synchronous and Ordered Templates
I don't know this way, think that info stayed there from ST or ST2...
BR,
Imics
Hi Imi, Do you mean to say this was possible in ST2 or earlier, unless you mean something else to say.
The hint line I mentioned and found in the Getting Started guide is so emphatic, I am sure it must be the case back then. Not sure why they discontinued this cool functionality. It is highly desirable to have separate templates for Ordered and Synchronous.
Tushar
Hey Tushar,
in pre ST3 versions you couldn't mix syncronous and ordered in one part. I think the separate templates option died with ST3. I work with syncronous for over two years now and i don't miss the separate templates. Switching modes is one click.
Greetings from Germany
Christian
Christian Kunkel
https://c-k-m.info
Hi Christian, thanks for the info. Having missed the first few versions of ST, I also got a bit obsessed with the separate templates idea for a short while. Yes, it takes just a click to switch modes - happy with it.
Tushar
