Synchronous part/assembly accidental copy and Accidentally switching to perspective view.
Annoying problems this morning. Is there a way to disable copying parts and/or assembly using the keyboard shortcut and the steering wheel?I keep accidentally duplicating assemblies and parts with the steering wheel since I use ctrl+shift +mouse wheel to pan. Is there a way to disable the possibility of compying a object with the steering wheel + ctrl?
And since I use ctrl+shift+mouse wheel to pan I often sitch to perspective view accidentally wich is very annoying, can I disable perspective view completely?
ST9
Conveyor and industrial equipment designer.
Giving SE a chance.
Re: Synchronous part/assembly accidental copy and Accidentally switching to perspective view.
MLombard
Retired
How about just using Shift-mmb to pan instead of changing the way the software works?
Oh....my bad lol!
ST9
Giving SE a chance.
