SystemsParts on SE9 Win10?
After years I finally could install the standard parts tool on my PC. WHAT A MESS!!!
D*mn, could one make a tool less usable?
So I tried to install my good old SystemsParts from StreamDesign on my new PC, but can't make it work like it did.
Anybody who has an idea how I could tell Systems Parts SE is running?
DR7mEfs
Solid Edge 2019 & AutoCAD 2020 user
6 REPLIES 6
Re: SystemsParts on SE9 Win10?
Hi Joris,
Contact Arne Brohuus or Thomas Thygesen from stream design direct to solve this problem
Kind Regards,
Jan Bos
Emmen, The Netherlands
User Since V3.5
My LinkedIn invitation to Thomas was send a few days ago, now I added one for Arne to.
Let's hope one of them can and want to help.
Hi Joris
The old System part will not work on Windows 10, if you installe it, in its standard folder.
You can try to install it in your documents folder under your user profile.
I have had some luck making it work that way.
BR Jørgen
BR
Jørgen Vinther
Nextage Group PLM
Thanks for your suggestion, but unfortunately it doesn't help here.
jyTyCYX
Mayby System Parts is the 32 bit version???
ST9 is only supports 64bit.
BR
Jørgen Vinther
Nextage Group PLM
Indeed, the 32bit version I suppose.
