Technical Requirements
I am currently using Solid Edge 2019 MP02 and when I insert reference text into techincal requirements the resulting pdf has the text stack onto each.  Is there a way to tell if this issues has report written up for it?  See attachment for example
14 REPLIES 14
Re: Technical Requirements
I am not able to recreate this issue.
Moreover, the image doesn't look like Technical Requirement, since I cannot see the numbering as 1, 2, 3 or a, b, c, etc.
Can you attach the Draft file?
Betreff: Technical Requirements
Hi @lostriver319
no, seems working as expected here
Wolfgang
Hi @lostriver319
and PDF output is OK too!
Wolfgang
Draft example.PNGAttached is the draft and exported pdf.  Ignore that is says error: no reference, the issue still applies if there is a reference
Hi @lostriver319
and here is the PDF out of it.
No problems so far!
Wolfgang
I cannot reproduce the issue either.
@lostriver319 one thing you have not provided is how are you creating the PDF file?  Hopefully using Save As Translated -> PDF.
In your example you are not putting in an reference text between "12255-*-1"
You are correct I am using save as translated to get the pdf
Hi @lostriver319
if this post is pointing to my answer, then - of ocurse there is the reference text, as I opend YOur draft without any changes.
The only difference visible in that view/image is, that I have set to not show any reference errors, but a "-" instead.
Wolfgang
