Template Style
Someone could explain to me how deleting line or table style?
Why is the button 'delete' sometimes not enabled?
See below image (Italian language).
Re: Template Style
I suppose there is somewhere something in your template that uses this linetype.
Solid Edge 2019 & AutoCAD 2019 user
Re: Template Style
I do not believe you can delete the OOTB Styles
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
Re: Template Style
Why, in god's name would you want to delete the ability to have hidden lines?
Solid Edge 2019
Windows 7 Professional
Nvidia K2200 & Intel Xeon
"You're doing it wrong"
Re: Template Style
Possibly because they want to define a different custom spacing format. Then remove the supplied style and name new style hidden.
I would very much like to be able to remove some of the stock dimension styles, not allowed to do that though. Big Brother doesn't allow that !
Gary Dinges | Mechanical Design Engineer II | Probes & New Product Development Emerson Commercial & Residential Solutions | Therm-O-Disc, Inc.| 1320 South Main Street | Mansfield | OH | 44907 | USA T +1 419 525 8554 gary.dinges@emerson.com
