Text Profile: Continued
PLM World Member Builder PLM World Member Builder
Continued from previous question: Also, How to add text sentence to curved or angled extrusion.
http://screencast.com/t/WGmswezp
Thank You
Sketching tab, Insert Group, Text Profile   HTH
HTH
Matt Johnson
Application Engineer
Ally PLM Solutions
matt.johnson@allyplm.com
http://allyplm.com/
Text Profiles must be placed on a planar surface.  That b...
Text Profiles must be placed on a planar surface.  That being said, after a Text Profile is placed, there are tools on the Surfacing tab called Wrap Sketch or Project that can be used to map the text to a curved or multi-angled face.  If you are placing text on a planar surface but the text must bend to match a curve, place the curve as a sketch, place the Text Profile, and then drag the Text Profile and attach it to the curve.
http://Grundey.blogspot.com
