Thank you replies
N/A
Option 2 worked well for me!
Re: Welcome to the Solid Edge 45-day trial
N/A
As a quick introduction, I manage global marketing for Solid Edge and would like to first thank you for considering Solid Edge and downloading a 45-day trial version. Included in this version is award winning synchronous technology that has proven successful in helping companies like yours design better.
To help you maximize your trial feel free to ask questions or post tips in the forum—I think you will find the support here invaluable in learning more about Solid Edge. Also don’t forget that I’ll be sending you tips and tricks so check your email inbox every week. If you need help getting started, download this handy guide as it will walk you through how to get Solid Edge up and running and what your first steps should be. Also enclosed is “General Trial Test Plan” that can be used to guide your trial so you can explore the main areas of Solid Edge.
Thanks again, and design better.
Kris Kasprzak
Director, Solid Edge Marketing
Thanks Kris!
Thomas Herring, PE
N/A
thanks so far,
is there only an 32 bits ?
N/A
Thank you, Kris. I'll see if someone can explain me how to find the engineering reference in Solid Edge. The old way does not work.
Best Regards
Useful training videos
Solid Edge 45-day trial users,
All I hope your trial is going well. Here are a few tips and tricks videos that may teach you a few more things.
The steering wheel is a key part of using synchronous technology, these videos may help make you an expert.
http://www.youtube.com/user/SiemensPLM#p/c/BDBAE0719D7C3456/8/MpvuLPFhimk
http://www.youtube.com/user/SiemensPLM#p/c/BDBAE0719D7C3456/40/FriH3WydE88
If you are used to a different CAD system, the Command Finder may help you find your favorite command in Solid Edge
http://www.youtube.com/user/SiemensPLM#p/c/BDBAE0719D7C3456/15/PfNXQ7Qddsk
Learn some short cuts in view manipulation
http://www.youtube.com/user/SiemensPLM#p/c/BDBAE0719D7C3456/0/W2kqSYlKqwI
Stay tuned, I’ll post some more later.
Kris Kasprzak
