The assembly environment cannot be activated
I've got a huge problem. I cannot open any of my assemblies, SE say at startup that "The assembly environment cannot be activated." How can I solve this problem? What should I do?
Thanks for the answers,
Andrew
9 REPLIES 9
Re: The assembly environment cannot be activated
What kind of license do you have?
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
It is a Student Edition ST6, which I've downloaded from here:
https://www.plm.automation.siemens.com/en_us/academic/resources/solid-edge/student-download.cfm
I have already tried to reinstall SE, nothing happened...
What version/license were your existing assemblies created in?
The same one. I just reinstalled my Windows on my computer, thats all. I havent changed anything.
You could try uninstalling and reinstalling SE.
Using SE since V12, 2002
ST10 certified
Already tried, removed everything from the registry, from AppData, but the problem came back...
DEAR
I have same problem on Solid Edge startup, but I have Installed latest MP & my solid edge started.
I am use Solid Edge ST8 & SEMP08.
Irfan Pathan
Shree Infosys
Irfan:
Good update.
Andrew however used ST 6 academic version. A MP may not be applicable in his case.
~Tushar
Dear have you check the following?
Turn OFF the UAC and the Symantec endpoint protection and check if solid edge works.
