The big ER
Honored Contributor
Honored Contributor
I recently took the time to organize a majority of my ER's into a single letter. It is attached in PDF format.
I post this to see if other have any of the same problems and get some support from others for the same issues. If you do have any of the same issues, please file your own IR with GTAC so that the enhansements are done.
I will also add some of the file associated with the big ER if any are interested.
