There is a problem: find it yourself!
This kind of things are really  a PITA!
I download a model, I insert it in SE and try to change it in sync, so, I go to synchronous:
sigh...
Why isn't there a button "move model to synchronous"???
So: I move the body feature to synch myself.
HAHA! GOTCHA!
"There are faults" WHICH????
"You may use the Geometry Inspector" WHY ISN'T HERE A BUTTON TO THIS INSPECTOR????
It's all solved now, but hey, this could go a lot faster...
I don't ask big new features, no, I just ask the tools and buttons where they are needed. Nothing more. How hard can it be?
Solid Edge 2019 & AutoCAD 2020 user
5 REPLIES 5
Re: There is a problem: find it yourself!
valid inputs for submitting ERs...
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
I can't make ER's.
I live in Belgium.
I believe you do so thru your VAR.
You should be able to send them your screen shots and description and ask that they submit an ER and provide you with the NUmber as way to confirm it was submitted
Matt Johnson
Teamcenter 10.1.7
I gave up doing that.
Ever read this?
https://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/Call-for-Pet-Peeves-2-0/m-p/266373/...
Tons of super simple things but no result at all.
For example, this is years old:
It has been mentioned to our VAR('s) but still this complete obsolete step 2.
Honored Contributor
Honored Contributor
Classic CAD issues.
At least they tell you what's wrong. Better than many issues.
