They don't like each other I think
https://www.youtube.com/watch?v=O2klU9uPbaQ
Strange behaviour....
ST9 MP4
Solid Edge 2019 & AutoCAD 2019 user
3 REPLIES 3
Re: They don't like each other I think
Edit in place usually works better in this situations.
Otherwise you need to update all and sometimes open close the main asm too.
Thanks for your answer, but "usually" isn't a solution.
This must be correct, not sometimes but always.
I even restarted my PC and the problem is still there. This is a serious bug that needs serious attention.
I have send this to our VAR with the .asm. Let's hope for a quick fix.
Only log an IR can solve this kind of problems.
My advice was just to help you to reduce your issues by working in a proven more stable way.
