Thin Wall
I'm new here and i would like to seek for some help. Could anyone help me how to thin wall the attached file? I'm having problem doing such command, the error is "Unable to offset selected thin faces".
The area that should be open are the selected faces. And the thickness should be 0.8mm.
Thanks a lot.
18 REPLIES 18
Re: Thin Wall
Siemens Genius Siemens Genius
Siemens Genius
pls take a look on enclosed file.
Re: Thin Wall
Hi @TomQue,
Can you share how you did this? Thank you.
Re: Thin Wall
Hi there @Mikel06,
Works as expected for me.......what version of Solid Edge are you on?
Re: Thin Wall
Hi @SeanCresswell,
It's Solid Edge ST8, no MP installed.
Can you help me with the procedure? Maybe there's a problem with how I am doing it.
Thanks.
Re: Thin Wall
Siemens Genius
take a look on short video.
I have also ST18 MP12
Re: Thin Wall
Here's a short video.....
Re: Thin Wall
Good stuff @TomQue.....simultanious user support, your justa touch faster than me. Robot wink
Re: Thin Wall
I have same procedure but still error occurs on the file I'm working on. "Thinwall failed. The faces contain a curvature which is smaller than the offset distance.". But I tried on the Stp file and it works fine.
Re: Thin Wall
Can you show a video - can record one right from within Solid Edge.
