Threaded holes
Not applicable
Ho to position threaded holes
Re: Threaded holes
Siemens Master Siemens Master
Siemens Master
You may need to explain a bit more, but the basics are:
1. Place the hole using the "Place Hole" command. You can choose the threading and all there.
2. Use the "Smart Dimenson" command to place a dimension between the edge of the part and the top circle of the hole.
3. Edit the dimension to the value you desire.
