Threaded holes
New to Solid Edge,
How do you draw a threaded hole in Solid Edge 2D ST9, only seem to be able to draw normal circles and not the standard double circle (outside one broken/incomplete). Probably simple solution just don't seem able to see it anywhere.
Help much appreciated.
Re: Threaded holes
I do not tbelieve there to be a "sketch command" that draws  threaded hole representation.
Might suggest using a Block should this be a requirement of yours.
Matt Johnson
Teamcenter 10.1.7
Re: Threaded holes
Thanks for the reply Matt, will look into your suggestion to see if it works for me.
