Threads will not show on the 3D-model
What settings have I forgot
SE7 SP4
Thread don`t show.png?
ST10 MP6
Re: Threads will not show on the 3D-model
Hi there,
Not sure....all settings seem to be OK to me.
You might check in "Face Styles" that "Thread" the texture is pointing to the correct system image.
Solid Edge ST10 [MP8] Classic [x2 seats]
We have the same settings and no threads are visible.
When I render in Keyshot, the treads are visible.
ST10 MP6
Odd.....can you share that model, to see if it does the same on my system?
ST10 MP6
Looks like you may have your Color Manager set to "Use Solid Edge Options color settings".
Try View tab -> Style -> Color Manager -> Use individual part styles -> Threaded cylinders = Thread
From the help docs:
https://docs.plm.automation.siemens.com/tdoc/se/107/help/#uid:index_user_interface:xid458110:xid4581...
Yeah, just as Dave says......switch to "Use individual part styles" and should appear as expected.
JIPPY!!!!!!!
Thanks guys, everything is perfect!
Best regards,
Geir
ST10 MP6
What about in an assembly, if the assembly does not originally have a Thread Face Style. I can make a new face style and point it to the threads.jpg texture; but it still will not show the thread texture where it should?
On a similar note, could I copy a thread face style from a part that already has it to this assembly?
Srypstra
ST7 MP0 | Win7
Hi @Srypstra
for me this sounds like the assembly is not showing the part face colors.
If the thread face style is not available in the assembly (due to it is a very old one) then You can use the organize format styles feature to copy it from the materil.mtl or any other document back to Your assembly.
Wolfgang
