Title Block Author Auto Populate with Initials
Hi
I am wanting to auto populate my title block with the authors name but only want initials to show.
Can I alter this code %{Author} to pick up only the initials from my user profile?
Betreff: Title Block Author Auto Populate with Initials
HI @RF
no not as far as I know.
There only is a way to use user initials as user defined props or to change the system names as You want them to see on title block
Another method might be to use a macro for changing the system user name to an initial user name by API
Wolfgang
Yeah I'll have to change the user names to initials.
