Title Block Revision
Not applicable
I updated the font size on A4 sheet to fit my name in block. Since then new projects
load all sheets with name blanked out until I open a new sheet, which then updates
all other sheets to show name correctly.
Is there a way I can get SolidEdge to load sheets correctly at start up without
having to open a new sheet everytime?
Any help gratefully received.
3 REPLIES 3
Re: Title Block Revision
Not applicable
Chris,
I need to fully understand what you did.
What name are you seeing blanked out? Is it a callout? Is it a block? Is the
text on the background sheet?
When you say that you updated the font size, I assume you changed the style
to increase the text size.
Are you making the changes in your template file so that all new files
created from this template have the required changes?
Please provide some more information.
Rick B.
Not applicable
"Rick B." wrote:
>Chris,
>Thanks,
>Rick B.
Not applicable
"Rick B." wrote:
>Chris,
>Thanks,
>Rick B.
Hi Rick and thanks for your time, have sent details by Email hope thats ok
