Titleblock & revisons
Just wondering how you handle your Titleblocks on drawings.
- Are the filled in (semi)automatically or without any intelligent
- Are they inserted from other applications (excell, ERP system,...)
Re: Titleblock & revisons
ours are handled via Vb programs, populated automatically
Esteemed Contributor
We use property text to populate most of it from the drawing file.
Production: ST9 MP10
Testing: ST10 MP3
we had good results with using "Call Outs" vs text boxes in title block areas
we create custom attirbutes using VB which populate the title block fields
I use "call outs" with property text, mainly pulled from the part or assembly being documented in the draft file.  This helps me stay consistent in how I fill in the properties of my models.  This works well for me, however i am not in a "managed enviroment" ie no insight or team center, as this would have a bearing on where the data for for your TB should be pulled from.
HTH
Mike
I use callout text with inex references to fill out the title, and part number.  I use a callout with a reference to the revision of the draft file.  They save a lot of time when generating detail drawings.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
