Tolerance Chart
Good Afternoon,
Is there a great tolerance chart that has slip on fit clearance. Easy on hard off. (or) Will this be a taper fit?
Thank You
Greg
Re: Tolerance Chart
Hi Greg, I access this type of specific info from the machineries handbook. If you don't have access to one, a quick search on-line for limits and fits finds a pretty good table to download in PDF form. (sorry, on my phone so can't attach the doc)
Solid Edge ST10 [MP8] Classic [x2 seats]
