Tolerance alignent
To satisfy my OCD is it possible to align the tolerance in this dimension? i'd really like it to read +0.3 -0 and have the zeros aligned..
Betreff: Tolerance alignent
Hi
give a try to use the numerical tolerance function instead of the alphnumeric one
Wolfgang
Leading and Trailing "0" can be controled by dim style
Re: Tolerance alignent
Right click on dimension, select Properties, select Text. Change Align to setting to Decimal Point.
Attached picture od dimenions shows 2 identical dimensions, 3.0 +0.5/-0.2. Lower one is alinged by sign, upper one is aligned by decimal point.
Gary Dinges | Mechanical Design Engineer II | Probes & New Product Development Emerson Climate Technologies | Therm-O-Disc, Inc.| 1320 South Main Street | Mansfield | OH | 44907 | USA T +1 419 525 8554 gary.dinges@emerson.com
May even be better to do set in your dimension style and leave your OCD on this issue behind.
Bruce Shand
ST10 MP7 - Insight - Win10 - K4200
thanks Gary,
bshand, Logical next step Smiley Wink
