Re: Top Level Assy Warnings for Parts with Failed Features
Yes, It does make sense for my application having parent/child parts in assemblies.  It saves the user tons of time from having to verify each part manually to check for broken constraints between parts.
Thanks again Jason.
Matt
@MattS So your main concern is parts with interpart links? Not parts without links that have failed.
I think it would be useful to be able to see both cases.
Bruce Shand
I agree it would be useful to see both cases.
585 ST10 Win 7
Yes Bruce,  just need to see the errors in the assembly environment.  I model in ordered mode, so I can see the errors in the model tree in the part environment by the different icons.  I'm pretty new at SE and don't have any synchronous experience, so I can't comment on that.
What Jason came up with is such as time saver.  It's great!
