Trajectory
I have a little question, i installed Solid Edge 2d Drafting yesterday and i want to know if i can draw a trajectory and follow this trajectory with an object.
I wait your answers, Thanks.
Re: Trajectory
a little more detail may be needed but, in basic understanding, yes.
I would suggest using the connect relationship; note that you can connect a point to a chain, be sure to be aware of the status bar prompts during the creation of the relationship.
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
Re: Trajectory
 Ok, i'm french so it's hard to explain all in english.
I would to create some of plans of farm and in the corridors of this farm, a scraper will be move on a trajectory that i would to draw. And i want to say if the scraper will go in the wall for example.
So i have to put my scraper on the trajectory and i want he follows the trajectory. And i want to know if it's possible on Solid Edge 2D Drafting and how to make this, I don't know this software.
Re: Trajectory
maybe share a basic sketch or screenshot so we can see what it is you are doing..
but have a look at the Connect relationship Command... :
https://docs.plm.automation.siemens.com/tdoc/se/110/se_help/#uid:xid1129777:xid1323753:xid1317778:in...
this will be the key to getting your desired results... and also, probably Tangent relate
Matt Johnson
Teamcenter 10.1.7
Re: Trajectory
On the picture here, i have to follow the blue trajectory.
I will try to use your command. Thanks for your help
Re: Trajectory
OK,   try this,  Symmetrical Offset...
Matt Johnson
Teamcenter 10.1.7
Re: Trajectory
Ok, the symmetrical Offset is good, thanks.
But now that I have a good trajectory, can I move with something and following this line.
I don't know maybe associate a point with a line, block it on the line and if I move the object he follows
I'm sorry to disturb you with my question.
Thanks !
Re: Trajectory
Ok sorry i came to make your function and i understand ! Thanks you very much I think it's good, I will present my project to my boss. Thank you !
Re: Trajectory
yes,  this would take you back t using the connect relationship...
Matt Johnson
Teamcenter 10.1.7
Re: Trajectory
Hi Oliblast I would look in the help files for profile groups, you can create a profile and move an object along the profile
Good Luck
Pete
