Transfer Solid Edge settings
I did a search, but can't seem to remember as to how to "Sync" my workstation setup to my Surface Pro (home license).
hAs anyone made a quick script that SAVES all your customized Toolbars, Radial Menus, Materials, etc. to a backup that can be imported into say your laptop or home machine.
 I realize this is simpler then in the past, but I'm still missing something here.
Re: Transfer Solid Edge settings
Here i export part of the regerstry "HKEY_CURRENT_CONFIG\Software\Unigraphics Solutions\Solid Edge\Version 107" to a folder. then copy over the "Unigraphics" folder in C:\Users\"user"\AppData\Roaming.
I then go to the machine i want it on. log on as me. double click the reg file i saved. then copy and past the "Unigaphics" folder to the correct folder on that machine
