Re: Transfer option in assembly
Hi @chiosa_ciprian
is this happening on all assemblies or on specific ones only?
Wolfgang
According to the user on all asemblies. It doesn't matter if we are or not connected to the teamcenter...
Even if the user builds up an assembly from scratch, it still have the error.
Ciprian Chiosa
Solid Edge ST8 + TC10.1 - Win 7 x64
SIPA Enginnering Romania
Hi @chiosa_ciprian
is it possible to make a short video showing what You are doing, where You are, what happens (or not) and so on
Wolfgang
Well ... it is quite difficult.
In all the cases: the user started to work, and then when he tried to move some parts from one assembly to another, the button, the function it is present in the toolbar but it is not active.
Then I close Solid Edge, make the registry changes, the command it is active, and they can continue their job.
And it works fine for 2-3 days, and then... here we go again. Not active, doesn't work...
Somehow, I have a feeling, that it MIGHT be something with pop-ups / notifications.... You know there are some sites that ask you permission to send notifications... and I am afraid that maybe it's because of that. We are using Chrome as a web browser.
Ciprian Chiosa
Hi @chiosa_ciprian
allow me a obvious silly question:
"Is somebody plugging on any USB device/phone?"
Wolfgang
well...on 2 PC's yes. USB charging cable...
Ciprian Chiosa
Hi @chiosa_ciprian
So in that case I would like to suggest, to not plug in those cables anymore and see wether then the problem occurs too or not.
I have in mind, that we had big problems with user interface, tabs, etc. and reason for that - finally turned out - were phones (iphone in that case) which were plugged into the USB ports of these computers.
Stopping this, let all problems disappear immediately.
Wolfgang
Ah...what can I say.... ?! At least we can try it.... I'll try to come back in a few days with a feed-back.
Thanks!
Ciprian Chiosa
Hi @chiosa_ciprian
expecting Your answer in a couple of days
Wolfgang
Still monitoring the situation. So far, so good.
Ciprian Chiosa
