Trouble copying feature in part
Hi everyone,
I've been learning Solid Edge recently and I have encountered a frustrating problem. I'm trying to use the feature library function while building my part, but for some reason, I cannot for the life of me understand, I can't copy any feature except sketches.
I tried this within both ordered and synchronous environment. Does anyone know what I could be doing wrong? :/
3 REPLIES 3
Re: Trouble copying feature in part
Are you trying to copy a sphere to the library. I found no problem Copy-Pasting to the feature library and putting it back into the model.
What method are you following to create a library feature?
Are you trying to use a LibFeature created in Ordered in Sync or vice-versa ?
~Tushar
Hi Tushar,
I have no idea why but the problem went away. Frustrating when you don't
understand why the software behaves the way it does, but I have too little
time and too much bachelor thesis to write to worry about it. Thanks anyway!
Fredrik Lundström
Hi Fredrik:
Glad that the problem went away.
It seems, some  times the best way to solve a Solid Edge problem is to wait it out.
~Tushar
