Re: Trying to create an assembly feature - sweep to create a wire
I am having the same issue with Sweep command.
I am in Weldments environment and Sweep command doesn't work.
I will try the Frame environment to create it..
Small update:
I have started doing my plumbing design using Frame environment and I have to say it is working very well.
Thank you @Howcad
Hi @arekkul
welcome!
Great to be able helping
Wolfgang
The only downside in using frames frames is not being able to define different radii for bends, but you can in XPresRoute.
For flexibles in frames, I usually place a spline curve for the path - gives a much more realistic result.
HP Z420 16GB RAM
Quadro K4000
@beachcomber
yes, I would have the XPresRoute license .... but without it I have to find a different method.
Arek
Hi @beachcomber
this IMHO isn't true.
You also can define every bend radius on every corner, as You like.
Wolfgang
and here You have a short video showing this:
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
Wolfgang
@Howcad
you are the Star !!!
I didn't know this method.
Arek
