Trying to flatten a surface
Looking for some help,
How come I cannot flatten the red surface? I can copy the surface and thicken it.
How do I upload the file? Whenever I try to attach it, I get a message that says "
The contents of the attachment doesn't match its file type."
All ideas appreciated.
Re: Trying to flatten a surface
@Greybarn   .zip the file then upload the zip.
is this a part model or sheet metal?  are you trying to flatten via sheet metal or part env?
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
This is a part model. I have attached an zipped up, unlinked version of the part file.
I was able to get a flattened surface by copy one of the surfaces, thickening it, adding a body, hiding the original body, and then making a blank body. But I have never gone through that many steps before.
Peter
