Trying to open an X_T file...
N/A
I need some help, When I am trying to open an X_T file I get an error code:
"Translation
The output folder does not exist ordoes not have write access. Select a new output folder."
I have tried to use different folders and even save stuff on different drives with no success.
Re: Trying to open an X_T file...
It writes back to where the X_T file is located. It must be located in a writeable folder (no optical drives) such as C:\Temp.
Production: ST10 MP6
Testing: SE 2019
