Trying to use fillet, but it isn't doing anything
Here is a video of me not using fillet
https://www.youtube.com/watch?v=gaTBYTC6hk0&index=1&list=UUw5olfQGGdD4D3-0QAhhz6Q
Normally with Solidworks I would just click fillet and then what I want to round.  Not sure how to get it to work with Solid Edge
1 REPLY 1
Re: Trying to use fillet, but it isn't doing anything
The reason you are not getting the fillet is because you may notice you are attampting to use the Fillet command in the Draw section of the Sketching tab, which is for sketches.  Since you are trying to fillet a solid, perhaps try the Round command in the Solids section of the Home tab.
http://Grundey.blogspot.com
