Tubing, wire, and weld paths, how do you turn the off?
I have run into this problem. I do not want to show the path line in my rendering, model view, or in my drafts but they keep showing up. I have tried and turned off the centerling and flow lines but it does not seem to be connected with it. any ideas?
the lines circled in red would be weld paths or weld labels
the lines circled in blue would be wire paths
the lines circled in green would be tube paths
Nathan M. Gardner
https://www.etsy.com/people/NathanMGardner
Be sure to check out my work!!
Made in Maine Wood Carvings
Re: Tubing, wire, and weld paths, how do you turn the off?
Have you checked under the Annotation tab, there are few more options to tweak that might be useful in your case.
