Tutorial page "Display the Layers tab on EdgeBar
Not applicable
Under Layers are listed Default,Dimensions, PartEdges, and Notes. When I go to this
page only Default is shown. How do I cause the others to be shown?
Thank you so much, your service is amazing.
Re: Tutorial page "Display the Layers tab on EdgeBar
Not applicable
George,
Are you following the tutorial? If you are, the drawing file that the
tutorial uses will have the layers shown created for you. If you create your
own new drawing file, the only layer that is created the Default layer.
Rick B.
Not applicable
>go to this
