Twisted Wire Thru Cyclinders
N/A
This may be an obvious answer! I figured I'll ask anyway. In this image there are six cylinders turning into three... with a hole on the side via line for lineament. Is there a way to put a hole on an angle for wire? or just put a hole on that angle.
http://screencast.com/t/vUrlwTQeF
Crousie
Re: Twisted Wire Thru Cyclinders
Esteemed Contributor
Hi Crousie,
Sorry, but from your description and then your image,...I still have no clue as to what you need to do here....so am struggling with how to help.
Just a thought...could you freehand sketch what you're looking to do, and scan & upload that?
Streetscape Limited (NZ)
Sent from my Samsung Galaxy NoteII using Tapatalk 2.
Solid Edge ST10 [MP6] Classic [x2 seats]
N/A
Hi Sean,
This video may help with what I trying to do, The aliment isn't that great... just to show the question I have. The yellow line is to show the arc for the wire travel. With both holes joined there is a void that can not get to. The measurement from the center 1.75 in. is the end of the hole, however, I had to come from the left to install the other hole. Any ideas for the void at the center or come from the side?
Crousie
>>video??? <<
N/A
Sean, Sorry for not having the video in the contents. This is the video.
http://screencast.com/t/p3JdhLHLN7
Crousie
Crousie,
I would switch to Ordered mode for this operation and use a couple of correctly positioned sketches to define a swept cutout, or if you really needed to use the hole command, place use the plane normal to curve option.
HTH.
