Un-Binder-ing files
Is there any way to delete the links to files once you have entered them in the Binder?
I only see add and edit.
I have tried everything I can think of up to and including manually deleting the attached file. This just leaves error messages galore.
Thank you for your help Man Happy
Gabriel Gullickson
Mechanical Drafter
Spectrum Industries
ST8
Re: Un-Binder-ing files
In the Binder window, select and press DEL on your keyboard...
Alex
Good Marketing makes the company look smart.
Great Marketing makes the customer feel smart.
Oh my goodness. That was too easy. I thought I had tried that but I must not have. Thank you very much. I may try to delete this post to hide my shame Smiley Wink
Gabriel Gullickson
Mechanical Drafter
Spectrum Industries
ST8
You don't want to do that, there is most likely many other folks that will have this same question.
http://Grundey.blogspot.com
Honored Contributor
Honored Contributor
A year into using SE, about half my questions were answed with a "Doh!" on my end.
