Unable To Utilize Steering Wheel Command In The Text Profile
As You Can See I Have An Arbitrary Number 118 That I Designed For This Short Video... I Was Able To Utilize The Steering Wheel in Synchronous Part As Well As Ordered Part.
I Noticed The Steering Wheel Is Not Available Or Else I May Not Have The Right Command
Thank You
GregoryLee
Re: Unable To Utilize Steering Wheel Command In The Text Profile
Hi there @PO_LC,
Your video is set to private, so cannot be viewed......You'll need to alter the setting to unlisted, rather than private, for others to view it.
Available Via. Unlisted
OK, I see what you are refering to there......and all seems to be working as designed.
Steering wheel available for Synchronous work, and not there for Ordered entities.
