Unable to ACTIVATE Solid edge 45 days free trial.
N/A
Hi All,
Kindly help me ACTIVATE Solid edge 45 days free trial.
After i enter the 16 digit activate code from the License utility, it gives an error
" Solid edge Activation could not connect to internet.
Check your internet and firewall connection and try again."
UAC is set to "Never Notify" Internet is working.
Re: Unable to ACTIVATE Solid edge 45 days free trial.
N/A
i am still wating for an Answer from "Expert".
Esteemed Contributor
Not certain what the issue could be, but if you installed SE to the default location, the file c:\Program Files\Solid Edge ST5\Program\selicense.dat may be 'read only'. You need to make this file 'writeable' if it is not.
Production: ST10 MP5
Testing: SE 2019
N/A
I have the same problem...I try to activate my 45 day trial version but there's allwas an error during the activation.
The status bar just starts then the error window pops up. I'm loggeg in as admin & firewall is off. Could somebody help me please?
What version of solid edge, and what version of windows?
Sent from my Motorola Electrify using Tapatalk 2
Testing: SE 2019
N/A
Windows 7 64bit, Solid Edge ST6 downloaded on Friday
I would suggest finding the nearest Channel Partner and contacting them for help. I will reach out to a couple of individuals about possibly getting a response here as well.
http://www.plm.automation.siemens.com/en_us/partners/find_partner.cfm
Testing: SE 2019
Gentlemen, what I have been able to find out is this:
If you have used the registration code once to register Solid Edge on a machine, you cannot use it again, even if it is for the same machine. You will need to re-register to get a new code.
Testing: SE 2019
N/A
I have an activation code, and I would like to use the ST5 version. I got the code yesterday, but when I tried to activate I got an error message. According to the message my subscription has expired.
What is wrong?
N/A
I have enter act. code once, when i get the second code, but it is the same bproblem.
