Unable to Use Move Command
Since I Downloaded ST8...
I Are Unable To Use The Move Command, While The Move Command Is Working But, Not To The ST7 Software Standards. I've Always Used The Move Command... Holding Down The Shift and Or CTRL To Move Many Items But, Not With ST8. I Have To Copy Many Times To Get My Results.
I Noticed The Rotate Command On This ST8 That I Are Able To Hold Down The Shift And Or CTRL To Move Many Items. But Not The move Command.
Thank You
Gregory Lee
Re: Unable to Use Move Command
Esteemed Contributor
Greg,
Without knowing what it is you are trying to do exactly, it is hard to offer a more complete work flow, or alternate solution to your issue.
The move/rotate [etc] tools have always functioned as expected for us. [Ctrl key being a momentary switch for the "copy" function, during operation]
Solid Edge ST10 [MP6] Classic [x2 seats]
Sean,
With This Short Video I Will Show You What The Move Command Does In
Comparison To The Rotate Command Does.
With The Rotate Command... While Holding The Shift Or Ctrl, You Will Notice
There Is A Brief Blink To Each Thread.
However, While Holding The Shift Or Ctrl To The Move Command To Pick Up All
Of The Pattern, I Am Unable To Retieve The Rest Of The Thread.
https://youtu.be/giuBxugqdR4
Thank You
GregoryLee
Greg,
From your video, I still don't understand what your desired outcome is......most of what you show in the video is a little confusing to follow. You seem to want to move/rotate part of one, or more, aspects of polygon profiles.....regardless of the fact you want to use Shift, or Control keys.
Maybe what you need to do, is actually select your item[s], and then select the command you want to employ.....purely just to simplify the process.
