Unable to download in 24 hrs will the link still be active
Not applicable
Sir,
Due to unavailability of recommended operating system i am unable to download the file in 24 hrs. If i download it few days later will the link still be active if not what is the alternative.
Please reply as soon as possible.
Devin
devinchaudhary@live.com
Re: Unable to download in 24 hrs will the link still be active
Hi there Devin,
Unfortunately no, that link will expire, but here is a direct link to the file....
http://dl2.plm.automation.siemens.com/solidedge/SolidEdgeV105ENGLISH_32Bit.exe
You will still need the license file from the original message (save it to a known location on your system) and the message should guide you through the process of installing it, once you have the correct operating system.
You could download it now, & save both the license & install file to a DVD (or flash drive) in readiness.
Streetscape Limited (NZ)
sean@streetscape.co.nz
Sent from my Samsung Galaxy NoteII using Tapatalk 2.
Solid Edge ST10 [MP8] Classic [x2 seats]
Not applicable
should it take 2 hours to download
Hi there,
Time depends entirely on the speed of internet connection you have....the installation file to be downloaded is about 2GB, if I recall correctly, so this WILL take a while for sure.
If interuptions cause a restart, look at installing one of the free download managers available online, then try again.
Not applicable
What about the 64-bit version, is it available?
Hi there,
No, as far as I know, there is not going to be one. The 32bit version should be adequate for "almost" everyone, and I guess, that was the whole point.
64bit machines with a surplus of RAM will of course show a benefit of the free system memory available for Solid Edge to use.
With the commercial release of ST6 having just happened, the Student Edition shouldn't be too far behind.
Keep an eye out for it.
Actually ST6 was just 'announced'. Won't release for a few more weeks.
Sent from my Motorola Electrify using Tapatalk 2
Production: ST10 MP7
Testing: SE 2019
http://Grundey.blogspot.com
