Unable to include
I have a strange situation where I am unable to include any lines from a part in the upper levels.
the screenshot is in a sketch in a part created in place and the blue part is in the assembly, I can not select any edges with the include command but I can select the sketch, the part is activated.
What is strange is the blue color, it should be gray.
11 REPLIES 11
Re: Unable to include
Hello Norbert,
I think if you enable "Peers" command for edge locate in Sketch env. , it will work.
See pic:
Ota
sadly that isn't it, I still think it has something to do with how the upper level part is displayed but I don't know what it is.
Can you provide a sample of your asembly and part?
There is the whole assembly
the problem seems to be once you are in edit mode in the part with the name 100000143930_sep_000
Thanks for asm.
I am able to include any geometry, so there should be something different on your system.
My suggestions: I have ST9 with latest MP, according to file prop. of your files you have ST8 with no MP. Do you have a chance to upgrade SE to latest release or at least can you instal latest MP for ST8? It is possible that there were a some small bugs in initial release of ST8.
Ota
the problem is if I make a new assembly with a new part created in place it works, sadly I have no possibility of an upgrade now
Ok, then I would suggest upgrading ST8 to latest MP when you will have a chance.
Ota
Are the parts active?
yes they are
