Unable to install Solid Edge ST7
After filling the form for students, and receiving a code and a download link,
I downloaded the file, and double clicked it and a message box appeared that said "Corrupted File".
I have downloaded the file in the past and the installation has worked, I have no idea why it isn't working now.
Thanks in advance Smiley Happy
Re: Unable to install Solid Edge ST7
We've just moved the Soild Edge Student Edition and Solid Edge High School Edition to our latest release (ST7).  During the switch over we have encountered a few issues but these have now been resolved.
Could I ask you to please re-download the install executable and then install.  you can also download an installation guide from the same place that will help step you through the installation process.
Thnak you for using Sold Edge
Mike Brown
this problem is still happening to me, "Corrupted file" what can i do? i need this program urgently
i need the spanish version please
Please re-download the Solid Edge executable.  the link sent to you following registration will take you to a protected download server where you can select your software language of choice.
If you've not recently registered please do so at www.siemens.com/plm/solid-edge-student
I download the .exe for installing Solid Edge, but when I want to launch the instal, i get a message "file is corrupt".
Hi there,
Then, the ONLY course of action for you, is to "re-download" the program.
Can I suggest using the download manager for Google Chrome browser.....this has worked flawlessly for me numerous times.
Hi Guys,
I have huge problem with installation ST7.
I try install on Win 8.1 Pro 64bit (6,3, Build 9600).
About 80% of installation progress I receive Error.
"An error occured during the installation of assembly component {837BF1EB-D770-A01F-C8B3B9A1E18E} HRESULT: 0x80070002"
dr Google prompt, that potentially:
1. Problem with antivirus or anti-spyware,
2. Problem with framework .NET or C++
3. Problem with Microsoft Installer
4. Windows consistency
I try installation without antivir. I upgraded all frameworks.
I cleaned and refresh Windows (despite system is 1 month).
Unfortunately, no results.
I have not idea, what I can improve for installation ST7.
Maybe you have experience with this problem?
Thanks in advance for your help.
Best,
Marcin
Ok, Ive tried re-downloading it, turning off the anti virus stuff on my cp, and even tried older versions of the student version and it is still not working....My cp is running Windows 8.1 and is more than capable to run the software. I'm even using Unreal Engine on it. So how can I get it to work? I love the program when I used it in High School and would like to use it again. Every time I re-download it all I get is the corrupt file error.
