Unable to rotate an image
N/A
I have a drawing and have inserted a .bmp image into it.
For printing purposes, I needed to rotate the entire drawing 90 degrees. Unfortunately, the .bmp image does not rotate with everything else. Odd. I tried to rotate it individually, but no luck.
Using SolidEdge 2D Drafting ST
Any suggestions?
Thanks.
1 REPLY
Re: Unable to rotate an image
If you need to rotate the drawing because of printing, this is typically done with the landscape/portriate printer setting.
If you select the image and use the Rotate command, it should rotate.
Rick B.
